Hostgroup Summary performance
benhank
Post by benhank »
Hey guys
Thanks to Mr.Sax I got the performance of my nagios to scream! The only thing left is the Hostgroup Summary. It loads slower than any other component and I was wondering if there is anyway to speed it up that you guys know of.
Proudly running:
Nagios Network Analyser
Nagios Fusion
Re: Hostgroup Summary performance
Post by mcapra »
There aren't a ton of optimizations to be made on that page specifically outside of general PHP configuration, which I imagine the great Mr. Sax took care of ;)
There's been discussion of changing how hostgroups/servicegroups are traversed on the back-end, but that's probably not something that will be included in the next release. It's just a heavy operation with lots of considerations unfortunately.
benhank
Post by benhank »
>in darth vader voice< your answer does not please me commander Capra, you have failed me for the last time!" FORCE CHOKE , ben never to good with the force choke, promptly passes out from lack of air.... +_x lol ok man lock it up and thanks for the reply!
Proudly running:
Nagios Fusion
Post by dwhitfield »
I am going to lock the thread. Be sure to look for improvements in future versions (but not this particular improvement in the next release). Thank you for using the Nagios forums!
