I am seeing this error repeated in the message logs:
Oct 2 03:26:05 horcrux2 ndo2db: mysql_error: 'Table './nagios/nagios_logentries' is marked as crashed and last (automatic?) repair failed'
We had an incident over the weekend where Nagios was alerting numerous items down but spot checks showed the items up. Any ideas?
-Matt
Table error in DB
Re: Table error in DB
Run the DB repair script:
restart mysqld:
and check the log for errors/crashed tables:
./repair_databases.shCode: Select all
service mysqld restartCode: Select all
tail -50 /var/log/mysqld.logBe sure to check out our Knowledgebase for helpful articles and solutions!
I ran the script and am seeing this when tailing the log:
161003 13:04:07 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired
161003 13:04:07 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_customvariablestatus' is marked as crashed and should be repaired
161003 13:04:07 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
161003 13:04:08 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_servicestatus' is marked as crashed and should be repaired
161003 13:04:08 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_hoststatus' is marked as crashed and should be repaired
161003 13:04:08 [ERROR] /usr/libexec/mysqld: Table './nagios/nagios_customvariablestatus' is marked as crashed and should be repaired
How much space to you have on the hard drive?
Try running:
restart mysqld:
and check the log again:
df -hCode: Select all
mysqlcheck -r -f -uroot -pnagiosxi --all-databasesCode: Select all
tail /var/log/mysqld.logBe sure to check out our Knowledgebase for helpful articles and solutions!
The issue now appears resolved. Thanks for your assistance.
avandemore
Glad this resolved your issue fodorm. I'm closing this thread now. Please open a new one for any further issues.
Previous Nagios employee
