Hello All,
I am trying to setup nagios alerts for services. I have add a definition like max 5 check with 1 min retry interval. But I am getting notification in SOFT state also result into multiple notification. I want to avoid notification if services shows fluctuation for few minutes. Eg. if mem usages cross thresold value for 2 min. then nagios need not send notification. If the threshold value be same for 5 min then it should generate alert.
Please provide me some hits to achieve this.
Thanks in advance.
Getting service check alerts on each retry check
avandemore
Re: Getting service check alerts on each retry check
Check out the documentation, it is quite extensive.
Regarding your specific question, Object Definitions is a good resource specifically regarding the first_notification_delay directive.
Previous Nagios employee
