NagiosXI 5.29 -> 5.30 Issue
rajasegar
Post by rajasegar »
Did an upgrade and it fails at the following line.
Tried running again same problem
sudo ./upgrade
Dashlet looks ok...
CMD: cp -rf /usr/local/nagiosxi/tmp/2tcbp/rss_dashlet /usr/local/nagiosxi/html/includes/dashlets/
CMD: rm -rf /usr/local/nagiosxi/tmp/2tcbp
CMD: . /usr/local/nagiosxi/var/xi-sys.cfg && chown -R $nagiosuser /usr/local/nagiosxi/html/includes/dashlets/rss_dashlet
Done!
Dashlets installed/updated OK
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:2: ERROR:  column "api_key" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:3: ERROR:  column "api_enabled" of relation "xi_users" already exists
UPDATE 31
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:8: ERROR:  column "login_attempts" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:9: ERROR:  column "last_attempt" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:10: ERROR:  column "last_password_change" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:13: ERROR:  column "last_login" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:14: ERROR:  column "last_edited" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:15: ERROR:  column "last_edited_by" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:16: ERROR:  column "created_by" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:17: ERROR:  column "created_time" of relation "xi_users" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:24: ERROR:  relation "xi_eventqueue_eventqueue_id_seq" already exists
psql:nagiosxi/nagiosxi-db/mods/pgsql/schema_01.sql:33: ERROR:  relation "xi_eventqueue" already exists
ERROR 1045 (28000): Access denied for user 'nagiosql'@'localhost' (using password: YES)
[nagios@MYUCBPNAGIAPP01 nagiosxi]$
Database access seems fine
[nagios@MYUCBPNAGIAPP01 nagiosxi]$  mysql --user=nagiosql --password=nagiosxi --host=localhost
Welcome to the MySQL monitor.  Commands end with ; or \g.
Your MySQL connection id is 493630
Server version: 5.1.73 Source distribution
Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
Oracle is a registered trademark of Oracle Corporation and/or its
affiliates. Other names may be trademarks of their respective
owners.
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
mysql> use nagiosql
Reading table information for completion of table and column names
You can turn off this feature to get a quicker startup with -A
Database changed
mysql>
See attached installation log and the config.inc.php file
upgrade.zip
config.inc.zip
Previous upgrade was ok without any issues.
5 x Nagios 5.6.9 Enterprise Edition
RHEL 6 & 7
rrdcached & ramdisk optimisation
Re: NagiosXI 5.29 -> 5.30 Issue
Post by dwhitfield »
Could you post the output of echo "show grants for 'nagiosql'@'localhost';" | mysql -t -uroot -pnagiosxi nagiosql? Thanks!
Check out the solution posted here:
https://support.nagios.com/forum/viewto ... 25#p198128
rajasegar
Post by rajasegar »
dwhitfield wrote:Could you post the output of echo "show grants for 'nagiosql'@'localhost';" | mysql -t -uroot -pnagiosxi nagiosql? Thanks!
[nagios@nagiosprodxi3 debug]$ echo "show grants for 'nagiosql'@'localhost';" | mysql -t -uroot -pnagiosxi nagiosql
| Grants for nagiosql@localhost        |
| GRANT USAGE ON *.* TO 'nagiosql'@'localhost' IDENTIFIED BY PASSWORD '*244733929909A95DDF1A7F78DD067589B4092EE7' |
| GRANT ALL PRIVILEGES ON `nagiosql`.* TO 'nagiosql'@'localhost' WITH GRANT OPTION                                |
RHEL 6 & 7
rajasegar
Post by rajasegar »
lmiltchev wrote:Check out the solution posted here:
Thanks. Hope there will be better QC next time.
Please close this thread.
RHEL 6 & 7
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
