Getting error on Apply Configuration through WebConsole
sgoffar
Post by sgoffar »
Hi All,
When we are applying apply configuration from Configure-->Core Configuration Manager--> Apply Configuration it's showing below error.
Error: Service has no hosts and/or service_description (config file '/usr/local/nagios/etc/services/nix_check_filesystem_usr.cfg', starting on line 16)
But when we are checking from server. Pre-flight check is showing 0 error.
Even after deleting the file /usr/local/nagios/etc/services/nix_check_filesystem_usr.cfg same error is generating. Attached the screen short and log details.
Our Nagios version is: Nagios XI 2014R2.7.
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Re: Getting error on Apply Configuration through WebConsole
See what you have on line 16 in the "/usr/local/nagios/etc/services/nix_check_filesystem_usr.cfg" file. You will have to modify the "problem" service under the CCM, and make sure it has a host, and a valid service description.
sgoffar
Post by sgoffar »
Thanks for your reply.
The file don't have 16 line at all.
I have even deleted the service but still it's not work. Attached the service details.
host_name daert11
service_description NIX check /usr file system
hostgroup_name centos_linux_servers,redhat_linux_servers
display_name nix_check_filesystem_usr
check_command check_nrpe!check_disk!-a '-w 10% -c 5% -l -p /usr'!!!!!!
max_check_attempts 3
check_interval 5
retry_interval 1
check_period 24x7
register 1
Regards,
Sk Abdul Goffar
bwallace
Post by bwallace »
Hard to tell based off of that screenshot - everything looks alright there. When errors occur during 'Apply config' its usually a conflict between what the DB has on record and what the flat files have listed at the moment. The following process should resolve it:
In the XI UI go to:
Core Config Manager > Tools > Write Config Files
Then follow these steps in order:
delete (deletes all flat files)
write (creates new flat files based off of what is in MySQL)
verify (runs the nagios verify cmd)
* If verify is good = apply config
* If verify is bad = correct the corresponding error, then repeat these steps until there are no more errors. - If in any doubt, post the error here, hopefully it will provide more detail.
