Hello
I need to automatically update the warning and critical ranges of different services. Is there any way to do this? I have seen the api but do not see how they can be used for this purpose.
I appreciate any help and guidance
Automatic update warning and critical parameters
Re: Automatic update warning and critical parameters
For our REST API, you're right, I do not see any examples on how to modify settings. I only find examples of listing, adding / deleting new hosts or services. Perhaps someone else knows if this is possible via the API?
In the meantime, while not automatic, you can use the bulk modifications tool to quickly make simple changes. Go to Configure > Core Config Manager > Tools > Bulk Modifications and basically follow the prompts.
