Hello LOG Support
Please help with inserting source tag into the conf file attached
What would be the syntax to tag this source as "TEST" ?
figured one to be based of incoming port
trying to add port 4446 via iptables, but no success (no incoming data)
Please hep (recall some issues with LOG vs Firewall from the past
How to insert tagging (source tag) into the conf file
Re: How to insert tagging (source tag) into the conf file
I believe you'll actually want to tag it based on the input, on the NLS side.
Simply create a new input like this for port 4446 -
(replace yourtag with what you'd like to specify as the type.)
tcp {
type => 'yourtag'
port => 3515
codec => json {
charset => 'CP1252'
Already had this onerkennedy wrote:I believe you'll actually want to tag it based on the input, on the NLS side.
Simply create a new input like this for port 4446 -(replace yourtag with what you'd like to specify as the type.)Code: Select all
tcp { type => 'yourtag' port => 3515 codec => json { charset => 'CP1252' } }
Tried port 3516 instead (opened iptables, created & aplied global config), but could not get incoming flow (works with 3515)
Just to make sure - did you apply configuration after making the change?
What is the output of iptables -L?
Here it is (actually most ports are not present; I am using -S instead which has different values)rkennedy wrote:Just to make sure - did you apply configuration after making the change?
[root@fikc-naglsprod01 /]# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT all -- anywhere anywhere state RELATED,ESTABLISHED
ACCEPT icmp -- anywhere anywhere
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:ssh
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:rich-cp
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:omnisky
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:5544
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:krb524
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:upnotifyp
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:must-backplane
ACCEPT tcp -- anywhere anywhere state NEW tcp dpts:vrace:sec-t4net-srv
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:https
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:nsca
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:nrpe
REJECT all -- anywhere anywhere reject-with icmp-host-prohibited
ACCEPT tcp -- anywhere anywhere state NEW tcp dpt:smartcard-port
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
If other ports aren't working, but you can get traffic over 3515 just fine, another option would be to set fields directly in nxlog. You can do this by modifying the <Output> rule like so:
Here's what my full Output looks like:
Exec $tags='super_cool_tag';Code: Select all
<Output out>
Module om_tcp
Host 192.168.67.200
Port 3515
Exec $tmpmessage = $Message; delete($Message); rename_field("tmpmessage","message");
Exec $raw_event = to_json();
# Uncomment for debug output
# Exec file_write('%ROOT%\data\nxlog_output.log', $raw_event + "\n");
</Output>Former Nagios employee
Thank you,mcapra wrote:If other ports aren't working, but you can get traffic over 3515 just fine, another option would be to set fields directly in nxlog. You can do this by modifying the <Output> rule like so:
Here's what my full Output looks like:Code: Select all
<Output out> Module om_tcp Host 192.168.67.200 Port 3515 Exec $tags='super_cool_tag'; Exec $tmpmessage = $Message; delete($Message); rename_field("tmpmessage","message"); Exec $raw_event = to_json(); # Uncomment for debug output # Exec file_write('%ROOT%\data\nxlog_output.log', $raw_event + "\n"); </Output>
please close this thread
