Monitoring Firewall setup
sth_bytelab
Post by sth_bytelab »
Hi
We have just bought a new firewall and are in the middle of making all the policies.
I would like to check all these policies use NagiosXI.
Do you guys have any suggestions about how to do this?
I have thought about checking the TCP-connections on every hosts, but is there a smart or better way?
Thanks!
Re: Monitoring Firewall setup
Post by dwhitfield »
If your firewall allows for stateful connections, just allow all outbound from the nagios XI server and only established inbound. Otherwise, installation requires (http,https,ftp,and ssh):
port 21
port 22
port 80
port 443
For deployment an monitoring, the necessary ports all depend on which agents and check you are running . . .
- @abrist, https://support.nagios.com/forum/viewto ... 17&p=57706
Please let us know if you have any additional questions.
