I try to add a bintec RS230aw Router for monitoring with the Router Configuration Wizard.
But it says no ports where detected.
I run the Troubleshooting Tip: /usr/bin/cfgmaker --show-op-down --noreversedns --zero-speed '100000000' '[email protected]:161::::1'
The result is attached.
Any idea where the problem is?
Thank you.
Configuration Wizard: NetworkRouter - No ports were detected
- Former Nagios Staff
Re: Configuration Wizard: NetworkRouter - No ports were dete
Could you please post the contents of /etc/sysconfig/system-config-firewall and /etc/sysconfig/iptables. Thanks!
