check_oracle_health
tdev457
check_oracle_health
Post by tdev457 »
I am new to nagios.When I use check_oracle_health with sql mode to query database I have follovin problem.
When the result is < 1 I receive message UNKNOWN - got no valid response for select.......
I need to store all possible results from query.How to change default behaviour of this plugin???
Thanks!!!
nscott
Re: check_oracle_health
Post by nscott »
tdev,
It is just a perl plugin, so you could edit it as you see fit. I'm not a perl guy, but what you'd just need to find where it checks to see if the value is -1 and remove it.
Nicholas Scott
