Can you suggest best tools for plotting graphs, reporting and Host mapping compatible with nagios core 3.x and 4.x , avaiabe ?
-A
nagios core | best tool for reporting, graphing and mapping
ericssonvietnam
ericssonvietnam
Re: nagios core | best tool for reporting, graphing and mapp
For mapping, You can take bellow (ur own url) as reference. I am trying to get something alike..
http://nagioscore.demos.nagios.com/nagi ... l?host=all
Please suggest..!
Please suggest..!
- Former Nagios Staff
For reporting, graphing, and mapping, there are multiple tools. We will need to know a bit more about what you want to do to give you the best option. You can start taking a look at https://exchange.nagios.org/directory/Addons/Reporting to get some ideas.
ericssonvietnam
Specifically , i am trying to achieve below one for mapping, please suggest best tool available.
Could you post the link or provide a screenshot as an example? The link you posted is not valid as it was truncated.
If you're looking for these features in something we maintain, the simple answer is going to be Nagios XI.
If all you want is literally the opening page of that demo, then you already have it! Just go to http://yournagiosserver/nagios/map.html
