NRDP don't send information
hdurans
Post by hdurans »
hello,
I have a problem with nrdp, it's configure and works until some days ago.
In this moment don´t send information to other server,
this is a log perfdataproc
# tail -50 /usr/local/nagiosxi/var/perfdataproc.log
Copying perfdata file to /usr/local/nagios/var/spool/perfdata/host-perfdata.1475965746
Copying perfdata file to /usr/local/nagios/var/spool/perfdata/service-perfdata.1475965746
Processing perfdata file '/usr/local/nagios/var/spool/xidpe/1475965746.perfdata.host'
Sending passive check data to NRDP server(s)...
Processing perfdata file '/usr/local/nagios/var/spool/xidpe/1475965746.perfdata.service'
  Sending to NRDP target host: XXX.XXX.XXX.XXX
    CMDLINE: cat /tmp/NRDPOUTpgfjPT | /usr/local/nrdp/clients/send_nrdp.sh -u http:// XXX.XXX.XXX.XXX/nrdp/ -t secret
    STDOUT: ERROR: The NRDP Server said
    RETURN CODE: 2
Copying perfdata file to /usr/local/nagios/var/spool/perfdata/host-perfdata.1475965761
Copying perfdata file to /usr/local/nagios/var/spool/perfdata/service-perfdata.1475965761
Processing perfdata file '/usr/local/nagios/var/spool/xidpe/1475965761.perfdata.host'
I review configuration and I don't find issue.
Reason: changed quote tag to code tag
Re: NRDP don't send information
Post by dwhitfield »
Can you upload a copy of /usr/local/nrdp/server/config.inc.php, scrubbing any confidential information? Alternatively, you can PM it to me.
Also, can you verify that the token in send_nrdp.sh matches the output of grep authorized_tokens /usr/local/nrdp/server/config.inc.php?
Thanks!
hdurans
Post by hdurans »
thanks for your help,
the server only send information, the nrpd server don't configured. the token is correct because it works fine until some days ago.
exist other server nagios xi configurate to recive to nrdp information, this works fine because recive data of other nagios to the same way.
when I make a test connection, it's works
[root@satelite ~]# telnet IPServerPrincipal 80
Trying IPServerPrincipal ...
Connected to IPServerPrincipal .
Escape character is '^]'.
when I make a test with send_nrdp.php, it's works, but when I try with send_nrdp.sh don't do it.
Thanks.
Did you recently upgrade your XI? What XI are you on now? What OS are you running? Did you recently upgrade your OS on either machine in question? I'm just trying to figure out what might have changed.
hdurans
Post by hdurans »
dwhitfield wrote:Did you recently upgrade your XI? What XI are you on now? What OS are you running? Did you recently upgrade your OS on either machine in question? I'm just trying to figure out what might have changed.
I don't change anything and don't update or upgrade someone.
the information of server
Nagios XI Installation Profile
Download Profile
System:
Nagios XI Version : 2014R2.7
src-dccw-012 2.6.32-573.3.1.el6.x86_64 x86_64
CentOS release 6.7 (Final)
Gnome is not installed
Apache Information
PHP Version: 5.3.3
Agent: Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/53.0.2785.143 Safari/537.36
Server Name: 10.92.65.98
Server Address: 10.92.65.98
Server Port: 80
Date/Time
PHP Timezone: America/Bogota
PHP Time: Thu, 13 Oct 2016 07:29:01 -0500
System Time: Thu, 13 Oct 2016 07:29:01 -0500
Nagios XI Data
License ends in:
nagios (pid 2074) is running...
NPCD running (pid 2012).
ndo2db (pid 2102) is running...
CPU Load 15: 0.21
Total Hosts: 23
Total Services: 309
Function 'get_base_uri' returns: http://10.92.65.98/nagiosxi/
Function 'get_base_url' returns: http://10.92.65.98/nagiosxi/
Function 'get_backend_url(internal_call=false)' returns: http://10.92.65.98/nagiosxi/includes/co ... rofile.php
Function 'get_backend_url(internal_call=true)' returns: http://localhost/nagiosxi/backend/
Ping Test localhost
Running:
/bin/ping -c 3 localhost 2>&1
PING localhost.localdomain (127.0.0.1) 56(84) bytes of data.
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=1 ttl=64 time=0.051 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=2 ttl=64 time=0.054 ms
64 bytes from localhost.localdomain (127.0.0.1): icmp_seq=3 ttl=64 time=0.050 ms
--- localhost.localdomain ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2000ms
rtt min/avg/max/mdev = 0.050/0.051/0.054/0.008 ms
Test wget To localhost
WGET From URL: http://localhost/nagiosxi/includes/components/ccm/
Running:
/usr/bin/wget http://localhost/nagiosxi/includes/components/ccm/
--2016-10-13 07:29:03-- http://localhost/nagiosxi/includes/components/ccm/
Resolving localhost... ::1, 127.0.0.1
Connecting to localhost|::1|:80... connected.
Length: unspecified [text/html]
Saving to: "/usr/local/nagiosxi/tmp/ccm_index.tmp"
0K ........ 645K=0.01s
2016-10-13 07:29:04 (645 KB/s) - "/usr/local/nagiosxi/tmp/ccm_index.tmp" saved [9167]
Network Settings
1: lo: mtu 65536 qdisc noqueue state UNKNOWN
link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
inet 127.0.0.1/8 scope host lo
inet6 ::1/128 scope host
valid_lft forever preferred_lft forever
2: eth0: mtu 1500 qdisc pfifo_fast state UP qlen 1000
link/ether 00:0c:29:21:99:d9 brd ff:ff:ff:ff:ff:ff
inet 10.92.65.98/24 brd 10.92.65.255 scope global eth0
inet6 fe80::20c:29ff:fe21:99d9/64 scope link
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
10.92.65.0 * 255.255.255.0 U 0 0 0 eth0
link-local * 255.255.0.0 U 1002 0 0 eth0
default 10.92.65.1 0.0.0.0 UG 0 0 0 eth0
hdurans wrote: the token is correct because it works fine until some days ago.
Even if you did not intend for something to change, something has changed, since it was working before. Can you verify that the token in send_nrdp.sh matches the output of grep authorized_tokens /usr/local/nrdp/server/config.inc.php?. NRDP tokens don't expire, but maybe there is a weird corruption issue going on or another admin fat-fingered a file or something.
hdurans
Post by hdurans »
hi,
I upgrade the nagios xi to last version, but don't solve the problem, It's the same error,
I'm thinking the isue is in "curl" comand.
Did you verify that the token in send_nrdp.sh matches the output of grep authorized_tokens /usr/local/nrdp/server/config.inc.php? I know you said you didn't change it, but I just want to verify nothing weird happened.
hdurans
Post by hdurans »
Yes, I verify and the token is correct, I try change but the error it's the same.
I'm try to nsca and it's work fine.
hdurans wrote: I'm try to nsca and it's work fine.
For the sake of clarity, are you saying you have resolved the issue, or are you not wanting to use NSCA? Thanks!
