Hi ,
We are trying out with Nagios Core and referencing the document - https://assets.nagios.com/downloads/nag ... 1473753267
to integrate selenium with Nagios.
Question:
1. The document states the compatibility with Nagios XI and we are wondering if this will work with Nagios Core as well ?
2. If there the document is meant for Nagios XI only, is there another Selenium plugin that we can use on Nagios Core?
Thanks.
Nagios Core with Selenium plugin Compatibility
[email protected]
Re: Nagios Core with Selenium plugin Compatibility
One thing to note - do not install Selenium on top of your Core environment. It will need it's own VM.
1. It should work fine for Core as well, as long as you have the per-requisites that XI has already.
2. There is not, the plugin will work the same between both. The only difference will be the configuration options that are specific to XI, you will need to adjust your changes accordingly.
