Graphing just stopped!
rredmond
Post by rredmond »
Good Morning! Yup, Ive had this problem before...and 3 different suggestions have solved it in the past but none of them work now! LOL At 11PM last night graphing just stopped. I reset credentials, I restarted, I checked npcd and Ive rebooted the box.......still no graphs. This ones got me stumped! Any logs I should be looking at? Anything else I can check? In the past it has been EMC that for some reason has crashed performance monitoring. Yet Ive always been able to restart it. Any help would be greatly appreciated..........
Randy
rredmond
Re: Graphing just stopped!
Post by rredmond »
Sorry, forgot...
NagiosXI 2009R1.2
Linux 2.6.18-164.9.1.e15
mguthrie
Post by mguthrie »
Usually in 2009 the performance graph issues were permissions related. Try running:
/usr/local/nagiosxi/scripts/reset_config_perms
And also accessing the Admin->Reset Security Credentials page, and resetting the credentials for the subsystem components.
rredmond
Post by rredmond »
As I pointed out above that was the second thing I tried with no effect. Ill give it another go.....
Do you see any errors in:
/usr/local/nagios/var/npcd.log
or
/usr/local/nagios/var/perfdata.log
rredmond
Post by rredmond »
I dont have either one of those logs. After doing the credential reset again{both} the nagios performance graphs started to show up. Added devices dont seem to show up until Ive scheduled an immediate check...although I COULD be impatient ;-) Very odd behavior..........
mguthrie
Post by mguthrie »
The rrdfiles for performance data are generated based on performance data that is received for a host or service, so if no results have ever come in for that service, there won't be rrd's for it. rrd files have a static filesize, so it's by design that new files aren't generated until there's actually data to put into them.
rredmond
Post by rredmond »
Well this is very bizzare! I am NOT getting graphs for anything that I dont schedule an immediate check for. In status detail for these hosts it says last check 2011-11-06 22:56:11 and next check 2011-11-07 23:00:00! Wth? If I schedule an immediate check it starts to graph as normal. Settings are to check every 5 minutes. That last check time is right around when our mystery even occured per the graphs. Any ideas on how I can force a check on 694 services without going one by one? Should I cycle the box again?
mguthrie
Post by mguthrie »
I would look at restarting the monitoring server. Oddities like this can sometimes be caused by multiple instances of Nagios running and competing with itself. A restart would take care of that, along with any other process that was acting out of sorts
rredmond
Post by rredmond »
I rebooted the server and the Last Check & Next Check date and time are exactly the same. Same results scheduleing an immediate check. SOMETHING changed the Next Check date and time on all these. Coincidently 24 hours after whatever incident caused this. The only thing that immediately started checking per config was Nagios itself. All of these devices are configured to check every 5 minutes yet they arent unless an immediate check is kicked off. I guess Im just waiting for all of these to kick off at 11PM tonight?
