Dear Team,
Please let us know can we monitor MAX DB from NagiosXI.
What are the parameters we can get for MAX Database.
Thanks and Regards,
Prasad
MAX DB monitoring
Re: MAX DB monitoring
Take a look at this plugin which should work for your needs - https://github.com/noisypebble/check_maxdb_health
It has quite a bit of documentation to explain the process as well, with what's needed for it to function properly.
