Unable to see views in Fusion
This support forum board is for questions relating to Nagios Fusion.
abodage
Post by abodage »
Hi Team,
I am unable to see my views created in Nagios Fusion.
My fusion version is Nagios Fusion 2014R1.1
Re: Unable to see views in Fusion
Could you show us a screenshot of what you're seeing so that we can better understand the issue here?
abodage
Post by abodage »
Hi rkennedy,
I create view using copy-paste url as shown below.
but when I click on Test the screen is transparent,
but when I tried it in Nagios XI its working properly.
Thanks.
Could you show us the URL you are attempting to use? It may be something to do with the characters in it, or perhaps a session of some sort to that specific link.
abodage
Post by abodage »
Hi rkennedy,
Below mentioned URL is using for views:
http://123.123.123.123/nagiosxi/includes/components/xicore/status.php?show=services&hostgroup=Network_Firewalls
Try appending &username=&ticket= to the end, so that it knows who to authenticate as. Here's an example (adjust the variables as needed, and use the proper API key) -
http://123.123.123.123/nagiosxi/includes/components/xicore/status.php?show=services&hostgroup=Network_Firewalls&username=nagiosxiusername&ticket=yourapikey
raamardhani7
Post by raamardhani7 »
rkennedy wrote:Try appending &username=&ticket= to the end, so that it knows who to authenticate as. Here's an example (adjust the variables as needed, and use the proper API key) -
Hi rkennedy,
Thanks for the solution. But its work only when I copy URL from old version i.e. Nagios XI 5.2.7
When I tried URL from latest version i.e. Nagios XI 5.3.0 then I face same issue.
please advise
Your ticket= is unique to each XI machine, so you will need to change that based on the machine you're checking.
abodage
Post by abodage »
Hi rkennedy,
rkennedy wrote:Your ticket= is unique to each XI machine, so you will need to change that based on the machine you're checking.
We have 4 XI machines in which 3 were upgraded with latest version 5.3.0 and 1 having 5.2.7.
I copied URL from all the machine with different API key associate with that server. Still i am unable to see views in fusion for upgraded server.
Please help.
I just tested this on my system, and it appears that some sort of stripping happens on the frame. If you click the links under 'My Views' and open as a new tab or window, they'll display properly, but not in the actual frame.
I filed this as a bug report internally, ID #9852.
