Can I do this with NLS?
http://logz.io/blog/analyze-salesforce-elk-stack/
Salesforce monitoring
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: Salesforce monitoring
The basic concept should work, but we don't have a Salesforce setup to test against. That plugin is definitely compatible with the version of logstash that NLS uses though:
https://www.elastic.co/guide/en/logstas ... force.html
After that, all you should need to do from the NLS end of things (if I understand the article correctly) is set up the input:
The article mentions a mutate filter as well, but that appears to be specific to the logz.io stuff.
[root@localhost ~]# /usr/local/nagioslogserver/logstash/bin/plugin install logstash-input-salesforce
Validating logstash-input-salesforce
Installing logstash-input-salesforce
Installation successfulThe article mentions a mutate filter as well, but that appears to be specific to the logz.io stuff.
