Dear Expert
Is there any Global setting in NagiosXI that if Number of Notifications get generated more than 50 in a minute time, Notifications get disable by Auto for 10 minutes and get enabled after that. Notification got Disabled / Enabled message should be there/viewable when we select HOME Notification menu/option
In the setting , No. of Notifications , Period, Halt Time......user will choose.
If there is no option, can you forward this to your design/developer team to add this as a new feature.
Our current version is XI 5.2.3
Regards
limit the Notifications per Minute
Re: limit the Notifications per Minute
That functionality doesn't currently exist, I agree that it would be a nice feature, I've created a feature request for you:
NEW TASK ID 9786 created - Nagios XI Feature Request: Add notification flood protection functionality
