After uprade to the latest version I am unable to unpin dashlets from a dashboards. When I click on unpin the blue border never appears again and a reload of the dashboard shows it as pinned again.
In this case I am moving some charts around but the issues affect the other objects.
Is there a scret new thing I have to click to get this working again. ?
Currently I need to edit the dashboard field in the metadata table and it is not pretty. Serializing and un-serializing as required.
Thank you
Sanjay
Unable to unpin dashlets
Re: Unable to unpin dashlets
I was able to recreate the issue, and filed an internal bug report (TASK ID 9794).
sanjayhiranisq
is there a hack I can do in the interim ? I just want to be able to move thing around since we trying to POC nagios and need to be live by the end of Oct if it rocks.
Thank you
Sanjay
Thank you
Sanjay
- Former Nagios Staff
There should be a fix out later this week, so end of October should work.
