White Labeling Nagios UI
gaugupt3
Post by gaugupt3 »
Is there a way for me to white label Nagios UI?
Gaurav
Re: White Labeling Nagios UI
Post by dwhitfield »
Of course! The source code is available at https://github.com/NagiosEnterprises/nagioscore
Please note the license for any changes you distribute: https://github.com/NagiosEnterprises/na ... er/LICENSE
gaugupt3
Post by gaugupt3 »
Thanks for quick response
By the way, if you are using an earlier version of Core, the source is available at https://sourceforge.net/projects/nagios ... ios-3.5.0/
A lot Linux distributions have packages for older versions. Most of our scripts and documentation assume you are building from source, so if you have a specific question, it would be best to build from source if you haven't already.
