How can I check all mounted filesystems on a hosts with NCPA
guglez
Post by guglez »
How can I check all mounted filesystems on a hosts with NCPA agent installed? Can I do that with out any extra plugins on remote servers? We do not use wizzard since we automated ncpa installation via ansible.
Re: How can I check all mounted filesystems on a hosts with
Post by mcapra »
I don't think you can send wildcard queries to NCPA at the moment, but you can check individual mounts/disks. If you visit the following:
https://<remote_host>:5693/api/disk?token=<your_ncpa_token>
It should list all the devices under the disk branch that were populated into NCPA. You'll probably want the mount or logical branch depending on how the devices were loaded into NCPA.
