I increased the number of services ( total 7827) and rebooted about 22 hours ago. all graphs have stopped showing metrics since that time so they all stop 22 hours ago. There is 11033 files as I write in /usr/local/nagios/var/spool/perfdata and none in xidpe or checkresults.
Please could you help figure out what is going on.
Perfdata failed
sanjayhiranisq
Re: Perfdata failed
Hi, ok
issue is resolved. I had another version of pnp4nagios installed and that somehow overwrote the startup script of the nagiosxi one. This caused an issue when I rebooted because it was looking in the wrong place for files .
I restarted the nagios one and removed the other one.
Thank you
Sanjay
Thank you
Sanjay
- Former Nagios Staff
Re: Perfdata failed
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
sanjayhiranisq
Re: Perfdata failed
Yes please close thread
