bulk host cloning
bulk host cloning
Does bulk host cloning work for all types of configurations ? for example, monitoring through SNMP?
avandemore
Re: bulk host cloning
How To Use The Bulk Host Cloning & Import Wizard. This document guides you through the wizard so that you can specify the services eg SNMP which should be with the new hosts.
Previous Nagios employee
does the bulk host cloning wizard deploy scripts in the remote system automatically ? (monitoring through ssh)
avandemore
No, something like NRDS will. Or use a configuration management tools like Puppet or Ansible.
