Hi
After upgrading to ver 5.3.0. I got lots of SNMP - error: Alarm signal (Nagios time-out). Is this related to the new version. No problem with the Previous Versions
have checked /usr/local/nagios/libexec/check_snmp_process_wizard.pl It`s default timeout setting are my $TIMEOUT;
SNMP - error: Alarm signal (Nagios time-out) after ugrade
Re: SNMP - error: Alarm signal (Nagios time-out) after ugrad
Was your check_snmp command using a higher timeout previously, before upgrading?
The command definitions that are built in to Nagios, get updated whenever a major upgrade comes in to play, so this could be the culprit.
christiandunn1
I am also experiencing the same issue after recent upgrades. I had been using the default values previously. Is there an easy way to increase the timeout for SNMP checks?
avandemore
5.3.1 has been released and is a bug fix only release. If you're running 5.3.0 and experiencing issues, upgrading again may resolve them for you.
@christiandunn1 -- In the future, please start a new thread specific to you. Feel free to link back to a relevant one if you wish. In response your question, you can rerun the wizard.
@mthjensen -- Are we good to lock this thread?
Previous Nagios employee
