Threshold Warning Critical not visible on Perf Graph
castroi
Post by castroi »
After upgrade to Nagios XI 5.3.x (same for 5.3.0 and 5.3.1) we cannot see anymore the threshold in performance graph for warning and critical for network bandwidth graph.
Is it a known regression ? Will be it be fixed in next release?
thank you,
Re: Threshold Warning Critical not visible on Perf Graph
You can enable graph buttons and warning/critical lines by going to Admin->System Settings->Theme & Display
Keep in mind that you will be able to see the buttons and/or lines only if you have 1 data point.
castroi
Post by castroi »
I have enable both as On but it is still the same, i also re-apply configuration.
I spoke with the developers, and this is due to not knowing where to set the line when there are multiple variables graphed. The warning / critical lines will only work when one variable is on it.
I filed a FR, for the updated functionality of working with multiple data points. The task ID is #9859.
castroi
Post by castroi »
All right, it will be appreciated to have it in upcoming release.
Thank you
No problem - I'll leave this thread open, feel free to respond to it should you want to check the status of the feature request.
castroi
Post by castroi »
Is the fix part of new release 5.3.2 ?
thank you
Post by mcapra »
That feature request is still pending. Here is the changelog for 5.3.2:
https://assets.nagios.com/downloads/nag ... NGES-5.TXT
