Can nagios XI support the azure remoteapp monitoring and its batch jobs IDs.
Please guide.
Azure Remoteapp monitoring
- Former Nagios Staff
Re: Azure Remoteapp monitoring
You might take a look at this listing on our Exchange site:
https://exchange.nagios.org/directory/P ... or/details
Out of the box XI does not have anything specifically for Azure, but our plugin system means other users can write and contribute their own plugins, which you are then free to use. Give that plugin a look and see if it will do all that you need! And if you need help installing or using any plugins, please let us know.
