Change default landing page
SavaSC
Post by SavaSC »
The default URL for nagiosxi is http://ServerName/NagiosXI. Unfortunately, that means that if you just go to http://ServerName that you then have to click on a link to take you to the \NagiosXI page. Is there any way to redirect traffic directly to the /NagiosXI page? I know how to do this with IIS but not with Apache.
Thanks!
bwallace
Re: Change default landing page
Post by bwallace »
This doc will show how to change the landing page:
https://assets.nagios.com/downloads/nag ... g-Page.pdf
SavaSC
Post by SavaSC »
Thank you for your response, but this is not the information I was looking for. I was trying to make it where people were automatically redirected to the log-in page instead of the "click here to get to the log-in page" page. The document you referenced tells how to change what page shows up after a user logs on. I was referring to before they log on.
Incidentally, I figured it out. You have to edit the following file:
/var/www/html/index.php
Somewhere in there (I put it in the header) stick the following code:
	<?php
	header("Location: http://ServerName.YourCompany.com/nagiosxi/");
BOOM! No more having to click twice to get to the login page.
This question has been answered. You can close this thread.
This will work, but index.php will be overwritten when you update.
I would rewrite this at an apache level rather then PHP, by doing the following:
Modify /etc/httpd/conf.d/nagiosxi.conf and look for -
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteCond %{REQUEST_FILENAME} !-f
RewriteCond %{REQUEST_FILENAME} !-d
RewriteRule nagiosxi/api/v1/(.*)$ /usr/local/nagiosxi/html/api/v1/index.php?request=$1 [QSA,NC,L]
</IfModule>
Before the </IfModule>, add this -
RedirectMatch ^/$ /nagiosxi/
Then restart httpd, and it will redirect / to /nagiosxi/.
gormank
Post by gormank »
Home Page Modification in admin manage components seems to be what you're looking for. The http://<nagios fqdn> leads to a page where you click a link to log in. http://<nagios fqdn>/nagiosxi leads to the page defined in components or a login prompt.
Thanks @gormank!
@SavaSC - let us know if you have any further questions.
SavaSC
Post by SavaSC »
gormank wrote:Home Page Modification in admin manage components seems to be what you're looking for. The http://<nagios fqdn> leads to a page where you click a link to log in. http://<nagios fqdn>/nagiosxi leads to the page defined in components or a login prompt.
Unless there is something I'm missing, this doesn't do what I am requesting. This is for after a user logs in, not before.
SavaSC
Post by SavaSC »
rkennedy wrote:This will work, but index.php will be overwritten when you update.
RewriteEngine On
</IfModule>
This worked! Thank you so much!
Post by mcapra »
Is it alright if we lock this thread and mark the issue as resolved, or did you need additional assistance with the landing page configuration?
SavaSC
Post by SavaSC »
You can lock it. Thank you for the assistance.
