Hi everyone,
Im trying to check two kind of things:
1) i need to check the size of a folder and / or archive.
2) the last modify date of one archive.
What plugin i need to use? and what is the code i have to use, one example pls.
Thx a lot!
NRDS
avandemore
Re: NRDS
What is the OS the files reside on? Also it's helpful to post your OS and version, and Nagios version for each new thread. Some users keep this info in their signature to expedite the process.
Previous Nagios employee
- Former Nagios Staff
Re: NRDS
The most recent version of XI is 5.3.1. You can see the version in the lower left of the WebUI. Can you tell use which version of XI you are using?
What format of archive are you using? https://exchange.nagios.com/directory/P ... ck/details should work for anything Windows sees as a file.
https://exchange.nagios.com/directory/P ... bs/details looks like it will work for folder size, and if the archives are files, you can use https://exchange.nagios.com/directory/P ... ze/details.
We don't maintain most of the plugins, so you may need to speak with a plugin maintainer.
For a lot of Windows monitoring, I would suggest you look at https://www.nsclient.org/
Reason: added a question about the version #
