[root@lkensherlockp01 tmp]# /usr/local/nagiosxi/scripts/./upgrade_to_latest.sh
http://: Invalid host name.
tar (child): nagiosxi-*.tar.gz: Cannot open: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
and finally i went old scool with the nagios upgrade pdf instructions:
Could not retrieve mirrorlist http://apt.sw.be/redhat/el6/en/mirrors-rpmforge error was
14: PYCURL ERROR 22 - "The requested URL returned error: 503 Service Unavailable"
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
how do I do this workaround? or should I attempt it?
[root@lkensherlockp01 nagiosxi]# yum clean all
Loaded plugins: fastestmirror, refresh-packagekit, security
Cleaning repos: base cr epel extras nagios-base nagiosxi-deps rpmforge updates
Cleaning up Everything
Cleaning up list of fastest mirrors
[root@lkensherlockp01 nagiosxi]# ./upgrade
Archive: sourceguardian/ixed4.lin.x86-64.zip
inflating: /usr/lib64/php/modules/ixed.5.3.lin
Sourceguardian extension found for PHP version 5.3
Sourceguardian extension already in php.ini
Stopping httpd: [ OK ]
Starting httpd: [ OK ]
Checking required prereqs...
Please wait...
OLD VERSION: 520
Setting up Remove Process
Resolving Dependencies
--> Running transaction check
---> Package rpmforge-release.x86_64 0:0.5.2-2.el6.rf will be erased
http://mirror.sfo12.us.leaseweb.net/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
Trying other mirror.
https://mirrors.kernel.org/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.math.princeton.edu/pub/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.us.leaseweb.net/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.cs.pitt.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.cogentco.com/pub/linux/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://fedora-epel.mirror.lstn.net/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://ftp.osuosl.org/pub/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirrors.mit.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.compevo.com/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
https://pubmirror1.math.uh.edu/fedora-buffet/epel/6/x86_64/repodata/repomd.xml: [Errno 14] PYCURL ERROR 7 - "couldn't connect to host"
http://linux.mirrors.es.net/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.cs.princeton.edu/pub/mirrors/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.metrocast.net/fedora/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirrors.syringanetworks.net/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
https://mirrors.lug.mtu.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
https://mirror.steadfast.net/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
https://mirror.chpc.utah.edu/pub/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://archive.linux.duke.edu/pub/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.sjc02.svwh.net/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.symnds.com/distributions/fedora-epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.nexcess.net/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.oss.ou.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://fedora.mirrors.pair.com/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.unl.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://mirror.prgmr.com/pub/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
https://mirrors.cat.pdx.edu/epel/6/x86_64/repodata/repomd.xml: [Errno -1] repomd.xml does not match metalink for epel
http://apt.sw.be/redhat/el6/en/x86_64/rpmforge/repodata/repomd.xml: [Errno 14] PYCURL ERROR 22 - "The requested URL returned error: 503 Service Unavailable"
Error: Cannot retrieve repository metadata (repomd.xml) for repository: rpmforge. Please verify its path and try again
Specifically check the line beginning with mirrorlist. It appears you have an old RPMforge definition containing an incorrectly URL. Make sure [rpmforge] contains:
