I executed force check and the scheduling went back to normal.
However it is scheduling every 5 minutes but not executing it.
By right it should schedule as per the time period, so the next check should be 23:46
Update: The scheduling is stuck at this. Next Check: 25/10/2016 08:37:00
Please advice on this.
define timeperiod {
timeperiod_name Time_clicks_CRON_TEMP_RECORDS
alias Time_clicks_CRON_TEMP_RECORDS
sunday 23:46-00:00
monday 23:46-00:00
tuesday 23:46-00:00
wednesday 23:46-00:00
thursday 23:46-00:00
friday 23:46-00:00
saturday 23:46-00:00
host_name MYCLKSUPRDDB02
service_description Cronjob : TM_RECON_FILE
check_period Time_Clicks_TM_RECON_FILE
check_command rs_fping_check_nrpe_unix!cronjob_check_status!TM_RECON_FILE!00!!!!!
contact_groups CGRP_APP_CLICKS,CGRP_TMC
notification_period Time_Clicks_TM_RECON_FILE
initial_state o
importance 0
check_interval 60.000000
retry_interval 5.000000
max_check_attempts 2
is_volatile 0
parallelize_check 1
active_checks_enabled 1
passive_checks_enabled 1
obsess 1
event_handler_enabled 1
low_flap_threshold 0.000000
high_flap_threshold 0.000000
flap_detection_enabled 1
flap_detection_options a
freshness_threshold 0
check_freshness 0
notification_options r,w,u,c
notifications_enabled 1
notification_interval 44640.000000
first_notification_delay 0.000000
stalking_options n
process_perf_data 1
retain_status_information 1
_CRITICAL_EMAIL true
_CRITICAL_REC_EMAIL true
_WARNING_EMAIL true
_WARNING_REC_EMAIL true
_WARNING_REC_SMS false
_WARNING_SMS false
_CRITICAL_SMS true
_CRITICAL_REC_SMS true
