I am trying to remove templates on all hosts, since my hosts are in the hostgroups, i can just assign the templates to hostgroup instead.
XI has change template under the bulk modification, but is there any way to remove ?
Bulk modification for templates
avandemore
Re: Bulk modification for templates
Sure is XI > Configure > Core Config Manager > Bulk Modifications Tool > Change Templates not working for you? It's an Enterprise feature so I'm not sure if that's related to your use. What version of XI are you using?
Previous Nagios employee
Enterprise version
I already tried that but "change template" dont work.
anyway i just found out that the host must have a template, regardless of the hostgroup has a template or not.
thanks..can close liaorf
Enterprise version
avandemore
A host is NOT required to have a template. Are you sure you want to close this thread?
In 2014R2.6 you can't even add a template to a HG in CCM. Is this a new feature in 5.x.y? Just curious...
avandemore
No it is not. It's better to open new threads for these types of questions.gormank wrote:In 2014R2.6 you can't even add a template to a HG in CCM. Is this a new feature in 5.x.y? Just curious...
