Redirecting check_http through another
sth_bytelab
Post by sth_bytelab »
I would like to check a proxywebservice running on another server. I can only reach the url through the server so I was wondering if I could redirecting the check_http through the server in order to reach the service?
Re: Redirecting check_http through another
You should be able to use check_http to do this, specifically with these parameters -
/usr/local/nagios/libexec/check_http -H <proxy> -p <proxyport> -b user:pass -u http://google.com
