problem in nagios web
hen1993
Post by hen1993 »
Moderator Edit: This thread has been moved from the Logserver section of the forum as it is not a Logserver question
In the future, please post issues in the correct sections of the forum
Error: Could not read host and service status information!
The most common cause of this error message (especially for new users), is the fact that Nagios is not actually running. If Nagios is indeed not running, this is a normal error message. It simply indicates that the CGIs could not obtain the current status of hosts and services that are being monitored. If you've just installed things, make sure you read the documentation on starting Nagios.
Some other things you should check in order to resolve this error include:
Check the Nagios log file for messages relating to startup or status data errors.
Always verify configuration options using the -v command-line option before starting or restarting Nagios!
Make sure you read the documentation on installing, configuring and running Nagios thoroughly before continuing. If all else fails, try sending a message to one of the mailing lists. More information can be found at http://www.nagios.org.
Re: problem in nagios web
Post by dwhitfield »
Hi @hen1993,
I have a few questions to help the community troubleshoot this issue with you.
What version of Core are you running?
Did you compile from source or did you using OS repos?
What OS/distribution and version # are you using?
What you tried anything to get nagios started?
Has this install ever worked?
Is there anything else installed on this server?
