All notifications not being sent!!!
BanditBBS
Post by BanditBBS »
This is a huge issue! I only noticed this once we went to 5.3.0, thought it may have been a fluke, but more instances of it were caught last night and we are on 5.3.1 now.
XI shows notifications going out to our servicedesk(sd) but they are not received by the sd. The are constantly monitoring the notifications report and comparing to their inbox and last night had some say sent but not show up. sd then emails me and lets me know. I then do my research, I have mail debug on and no errors around that time and no "Message Sent" at the time either, so of course nothing in the maillog file either. Its like phpmailer just isn't being called, like the notification handler is either not being called or not running properly! There is absolutely no pattern to this that I can find.
HELP!
2 of XI5.6.14 Prod/DR/DEV - Nagios LogServer 2 Nodes
See my projects on the Exchange at BanditBBS - Also check out my Nagios stuff on my personal page at Bandit's Home and at github
Re: All notifications not being sent!!!
Definitely aware of this, compiling a list of common tickets and threads right now since not everyone is having this issue. Devs think they know what the issue is, likely fix on the way. Stay tuned.
jomann
Development Lead
Post by jomann »
Are all notifications or just some notifications for certain services in particular? Can you send us your eventman.log with at least a bit of data in it - to see if this is related to the other issues or not.
BanditBBS
Post by BanditBBS »
It is not all, it is completely random.
[jclark@iss-chi-nag05 nagios]$ cat /usr/local/nagiosxi/var/eventman.log
.......PROCESS EVENT: ID=7410712, SOURCE=2, TYPE=1, TIME=2016-10-28 10:02:17
*** GLOBAL HANDLER...
Array
    [event_id] => 7410712
    [event_source] => 2
    [event_type] => 1
    [event_time] => 2016-10-28 10:02:17
    [event_meta] => Array
            [handler-type] => service
            [host] => rvbd-chi-dap02
            [service] => Zombie Processes
            [hostaddress] => 10.160.6.23
            [hoststate] => UP
            [hoststateid] => 0
            [hosteventid] => 3092758
            [hostproblemid] => 0
            [servicestate] => OK
            [servicestateid] => 0
            [lastservicestate] => WARNING
            [lastservicestateid] => 1
            [servicestatetype] => SOFT
            [currentattempt] => 2
            [maxattempts] => 3
            [serviceeventid] => 3629066
            [serviceproblemid] => 0
            [serviceoutput] => PROCS OK: 0 processes with STATE = Z
            [longserviceoutput] =>
            [servicedowntime] => 0
    [logging_enabled] => 1
*** GLOBAL HANDLER (snmptrapsender)...
Array
    [event_source] => 2
    [event_type] => 1
            [hoststate] => UP
            [hoststateid] => 0
            [maxattempts] => 3
SNMP TRAP SENDER NOT CONFIGURED!
PROCESSED 1 EVENTS
That is the entire contents of the log
jomann
Development Lead
Post by jomann »
Ah don't see the error in that log but it's like the cmdsubsys.log and it truncates every minute. Since it's random though it's likely the same issue that we saw in other systems. I'll let Trevor continue to manage this, I believe the fix should resolve this.
WillemDH
Post by WillemDH »
Has this issue been identified and resolved in 5.3.2?
Nagios XI 5.8.1
https://outsideit.net
Post by mcapra »
Essentially, events with special characters in their status information were not correctly being serialized when inserted into the database. I'm unsure if this is the exact issue you were facing, but it was an issue that affected several user's notifications and was fixed in 5.3.2.
