Error SNMP - PLug will show as critical if can connect
bosecorp
Post by bosecorp »
I monitor LINUX Servers via SNMP. if for some reason SNMP is not running on the client, the alert will show up as CRITICAL. I would like to show up as UNKNOWN.
is that possible?
Re: Error SNMP - PLug will show as critical if can connect
Post by mcapra »
It would depend on the specific snmp plugin being used since our wizards leverage a few different ones. You could probably write a wrapper script to re-write the exit code from 2 to 3 though for your specific checks.
bosecorp
Post by bosecorp »
Ok. that works. thanks a lot
please close the ticket
avandemore
Post by avandemore »
Good to hear this will work for you. Thanks for using the Nagios forums!
Previous Nagios employee
