Not all services are displayed
I have the servicegroup which have over 100 services. But when i tried to see in browser i get for example only ~95 services, but I need a lot of time to refresh the page in the browser to see all services.
It is problem with timeout in configuration files?
Thanks.
Thanks.
Re: Not all services are displayed
Could you post your /usr/local/nagios/var/objects.cache for us to review? This definitely sounds odd.
Are you using any addons on conjunction with Nagios Core?
I added this file, but I had to change addresses and emails in file.
I have only customer services on bash script.
objects.txt- (155.14 KiB) Downloaded 151 times
This looks fine from what I can tell. When you mention this -
After all of them finally appear, and you refresh again - are they showing for good after that? It might just be from an apply configuration happening as you have a somewhat large environment.
No, after reload page can change again the number of services.
I have to live with it?It might just be from an apply configuration happening as you have a somewhat large environment.
You didn't answer my question -
If so, then yes. There is probably some optimization that can be done though - what have you done so far?
Sorry, for my delay.
It was my answer for your question.
Within ~10 minutes it can be good. After the next reload the problem is appear.
after reload page can change again the number of services.After all of them finally appear, and you refresh again - are they showing for good after that?
- Former Nagios Staff
What version of Core are you using? If not 4.2.2, could you upgrade? https://assets.nagios.com/downloads/nag ... ading.html Thanks!
Hi, the last comment from https://support.nagios.com/forum/viewto ... =7&t=41316 helped me.
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
