Contact and Contact Groups and Specific Host
rbizzell39
Post by rbizzell39 »
I have been going over the documentation and currently I have windows.cfg with all windows servers. I am setting up contacts and I only want certain notifications to go to specific individuals. Do I have to create a separate config for those servers and then assign a contact to that group. Thanks!
rbizzell39
Re: Contact and Contact Groups and Specific Host
I created a contact in the contact group so do I go into my windows.cfg and add the contact to the specific host so on that particular user will get a notification
bwallace
Post by bwallace »
https://assets.nagios.com/downloads/nag ... ml#contact
Use the doc above as reference, but the most straight forward method is to create a contact group and of course add your contacts to that group. Then add that contact group to the host.
I like Ramesh Natarajan's helpful doc on the topic here:
http://www.thegeekstuff.com/2009/06/4-s ... tification
