I have a question about the reports Nagios gives out. When I put Hosts into a hostgroups it lists services at 100% OK when I view as a hostgroup but when I view the report of the host itself, the report shows more exact numbers such as 98.789% OK which is true over the time period.
Is there a reason for this? Is it because the hostgroup pie includes all of the other hosts and just rounds up to the nearest percent?
Nagios Reports
Re: Nagios Reports
Are the host groups large? Because I could certainly see the 100% error happening. I'm not sure when the switch from 99.9999... goes to 100, but it has to exist and that may be what you're facing.
Nicholas Scott
Re: Nagios Reports
Thanks for the reply,
That is what I assumed. The hostgroups are small though but even with more than one host I can see there being roundoffs. I just wondered if there was a reason for it or there was a way to change it. I will just do the reports of all the hosts individually and put them together.
Appreciate the quick answer
