Hi Guys,
I am trying to add a dashlet to a dashboard but every time that I go across ->dashboard->available dashlet and click the '->' nothing happens.
I have done this a lot of time in the past (on other installations) and never had problems with this.
Any ideas?
Already restarted Nagios and apache.
Regards,
Dashlet-Dashboard Error
maartin.pii
Re: Dashlet-Dashboard Error
Does this happen for all dashlets? Could you run tail -f /var/log/httpd/*_log and then attempt to do so once again? Wondering if there is an error that will pop up in your apache logs.
maartin.pii
Hi rkeneddy - It's been happening with all the dashboards - I will take a look on error.log of apache service and let you know.
Regards,
Regards,
avandemore
Please provide us the output of @rkennedy's command when you are ready to proceed.
Previous Nagios employee
maartin.pii
I just re installed this, and seems to be working now.
This thread can be closed - Not clear pattern founded in order to troubleshoot it.
Regards,
Regards,
- Former Nagios Staff
Glad to hear it is resolved. I am going to lock the thread. Please feel free to post again if you have you another issue. Thank you for using the Nagios forums!
