Where do I add this line please so I start monitoring bandwidth ?
check_eth -i eth0 -w 1024K Bps -c 2048K Bps
Thanks!
help with check_eth plugin
Re: help with check_eth plugin
Have you looked into our Core documentation?
https://assets.nagios.com/downloads/nag ... vices.html
While it is not specific to your exact plugin, it is essentially required reading for anyone looking to use Nagios Core. The documentation goes over all of the config options you will need.
Give that a read, check out some of the pages it links to, and let us know if you have further questions.
