No rule to make target `install-daemon-config' rpm binary
wice22
Post by wice22 »
I'm having an issue installing nrpe-3.0.1 (same issue with nrpe-3.0)
I'm getting the following:
# make install-daemon-config
make install-daemon-config make: *** No rule to make target `install-daemon-config'. Stop.
# cat /etc/redhat-release
CentOS Linux release 7.2.1511 (Core)
version : nrpe-3.0.1.tar.gz ( forom http://liquidtelecom.dl.sourceforge.net ... /nrpe-3.x/)
Please do let me know if you need any additional information. Any help will be highly appreciable?
Regards,
Zaza
Re: No rule to make target `install-daemon-config' rpm binar
Post by dwhitfield »
What instructions are you using for compile? You can find our instructions at https://support.nagios.com/kb/article.php?id=515
wice22
Post by wice22 »
Thanks for the fast reply
I was doing the following :
# ./configure
# make all
# make install-plugin
I'm going to start from scratch and will try to follow the manual from your link and will report if it works
Regards
Zaza
Something to think about while you run through those instructions: our instructions (almost?) always assume Core install from source, so you might need to change file paths if you are using distribution repos.
