I am getting 1st error on EMC monitoring but Even after resetting the password it's not working. So I have run the command
./naviseccli -User svcsnstor -Password SNstor01 -Scope 0 -AddUserSecurity -Address 172.x.x.x
After that I am getting 2nd error Anyone can help to resolve this.
1st error:
Error returned from Management Server on 172.x.x.x
Authentication failed. Possible reason for failure is excessive failed authentication attempts.
2nd Error:
There was a problem!
Perhaps the Monitoring Username OR Password are incorrect.
The returned result was:
Error returned from the Management Server on 172.22.111.221
Authentication failed. Possible reasons for failure are invalid security file, invalid username, password and/or scope.
Getting error on EMC monitoring
Regards,
Sk Abdul Goffar
Nagios Version:Nagios XI 5.4.8
OS:CentOS release 6.5
Sk Abdul Goffar
avandemore
Re: Getting error on EMC monitoring
We are not able to assist with custom plugin development or 3rd party plugins. Have you check Nagios Exchange for a plugin?
https://www.nagios.com/solutions/emc-monitoring/
https://exchange.nagios.org/index.php?o ... chword=emc
Also it appears naviseccli is an EMC specific tool, you will need to get to get that working first before trying to integrate it with Nagios. Check things like permissions.
Here is an example of a custom plugin: https://exchange.nagios.org/directory/T ... pt/details
Previous Nagios employee
