Set service check time-outs when not using check_nrpe
Nagios Core 3.5.1.
I am trying to use a blacklist plugin that I got from this link.
https://exchange.nagios.org/directory/P ... pl/details
I am running the plugin from the nagios server. I am not using check_nrpe to run it from the server being checked.
The plugin works fine from command line on the nagios server. However it times out at each scheduled interval. The error from the web page says "(Service check timed out)".
I have only been able to set a timeout when using check_nrpe. How can I set a longer timeout for a service check that does not use check_nrpe?
avandemore
Re: Set service check time-outs when not using check_nrpe
That is a quite old version of Nagios Core.
Please post the full command and output. What user are you running this as?
Previous Nagios employee
I have this in commands.cfg
From the command line I run this: (works fine)
From command line I run as root.
command_name check_rbl
command_line $USER1$/check_rbl <ip address>
./check_rbl <ip address>From command line I run as root.
avandemore
I'm asking for the output of the command, not the definition. EG:
Also to perform an accurate test, you need to run the command as user nagios EG:
# cd /usr/local/nagios/libexec
# ./check_dummy 0
OKCode: Select all
# su - nagios
$ cd /usr/local/nagios/libexec
$ <Your command here>
<Your command output here>Previous Nagios employee
[root@nagios plugins]# ./check_rbl <ip address>
All OK: SORBS, Distributed Sender, Spamhaus SBL/XBL/PBL, RFC-Ignorant, SpamCop, Mail-abuse.org, NJABL
[root@nagios plugins]# su - nagios
This account is currently not available.
[root@nagios plugins]# sudo -s -u nagios
bash-4.1$ cd /usr/lib64/nagios/plugins/
bash-4.1$ ./check_rbl <ip address>
bash-4.1$ whoami
nagios
bash-4.1$
avandemore
Timeouts per commands can be defined(most have it built in) eg:
From there, you can build services on top of it.
# ./check_ssh -h
check_ssh v2.0.3 (nagios-plugins 2.0.3)
Copyright (c) 1999 Remi Paulmier <[email protected]>
Copyright (c) 2000-2014 Nagios Plugin Development Team
<[email protected]>
Try to connect to an SSH server at specified server and port
Usage:
check_ssh [-4|-6] [-t <timeout>] [-r <remote version>] [-p <port>] <host>
Options:
-h, --help
Print detailed help screen
-V, --version
Print version information
--extra-opts=[section][@file]
Read options from an ini file. See
https://www.nagios-plugins.org/doc/extra-opts.html
for usage and examples.
-H, --hostname=ADDRESS
Host name, IP Address, or unix socket (must be an absolute path)
-p, --port=INTEGER
Port number (default: 22)
-4, --use-ipv4
Use IPv4 connection
-6, --use-ipv6
Use IPv6 connection
-t, --timeout=INTEGER
Seconds before connection times out (default: 10)
-r, --remote-version=STRING
Warn if string doesn't match expected server version (ex: OpenSSH_3.9p1)
-P, --remote-protocol=STRING
Warn if protocol doesn't match expected protocol version (ex: 2.0)
-v, --verbose
Show details for command-line debugging (Nagios may truncate output)
Send email to [email protected] if you have questions regarding use
of this software. To submit patches or suggest improvements, send email to
[email protected]Previous Nagios employee
This particular plugin does not have a timeout option, even if it did, I'd have to set it to longer than our default global service timeout of 60 seconds. Hypothetically though, which one takes precedence, the global one in nagios.cfg or the plugin?
avandemore
The global setting takes precedence(or it would be useless).
If you have something that is taking an abnormally long time to check, perhaps that's best addressed by a passive check.
