Hello Team,
Has anyone published dashboard? internally / externally over SSL
We are planning to publish the dashboards to our management team / client stake holders to view the availability status of their respective environments which are being monitored by Nagios XI 5.3.2
Any suggestion / guidance will be appreciated.
Regards,
Swapnil
Publishing Dashboard
Re: Publishing Dashboard
You can "deploy" a dashboard to specific Nagios XI users, but there isn't really a way to "publish" dashboards since they require an active Nagios XI session to be viewed. You could create an individual user for each stakeholder that is listed as a contact for each of their respective objects and deploy specific dashboards to those users. What a dashboard displays in terms of host/service status is typically specific to a given user's permissions though.
