nagios.service:Control process exited,code=exited status=203
mr_g_marsh
Post by mr_g_marsh »
Install seemed to go correctly and was running. Performed a system restart and now get this error when trying to start service on Ubuntu 16.04.1 LTS.
nagios.service
Loaded: loaded (/etc/systemd/system/nagios.service; bad; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2016-11-10 13:41:10 GMT; 12s ago
Process: 4698 ExecStart=/usr/lib/systemd/scripts/nagios start (code=exited, status=203/EXEC)
Nov 10 13:41:10 media-pc systemd[1]: Starting nagios.service...
Nov 10 13:41:10 media-pc systemd[1]: nagios.service: Control process exited, code=exited status=203
Nov 10 13:41:10 media-pc systemd[1]: Failed to start nagios.service.
Nov 10 13:41:10 media-pc systemd[1]: nagios.service: Unit entered failed state.
Nov 10 13:41:10 media-pc systemd[1]: nagios.service: Failed with result 'exit-code'.
Any help appriciated.
Re: nagios.service:Control process exited,code=exited status
Where are your nagios binary and config files located? Please run the following command as root and post the output, making sure to replace the paths as appropriate:
/path/to/nagios -v /path/to/nagios.cfg
