email notification
kemade
email notification
Post by kemade »
Nagios XI 5.3.0 linux 64bit (VmWare)
after repair mysql tables, nagios doesn't send email notification messages from any hosts or services.
test from ADMIN->SYSTEM CONFIG->Manage Email Settings->Send a Test Email was successfully sent
    A test email was sent to [email protected]
    Mailer said: [11-11-2016 10:41:36] Message sent! (method=smtp;host=10.10.2.101;port=25;security=none), Referer: admin/testemail.php
at User profile - "Enable notifications" is enabled, but time period tab is empty.
bwallace
Re: email notification
Post by bwallace »
There were issues with notifications in version 5.3.0 that have since been fixed in 5.3.2, you'll find instances of such in this forum. I'd recommend upgrading to 5.3.2 straight-away and we can troubleshoot from there if the issue persists. Until then we''ll be spinning our wheels with 5.3.0. Refer to these instructions for manually upgrading:
https://assets.nagios.com/downloads/nag ... ctions.pdf
