Monitoring FileMaker Pro
coredump66
Does anyone know of a check to monitor FileMaker Pro?
tonyyarusso
Re: Monitoring FileMaker Pro
I am not aware of any so far, there are none listed on the exchange, and the most Google seems to turn up is grepping process output to see if it claims to have something running.
We can do custom plugin development for you if that's something you'd be interested in getting a quote for.
coredump66
Thank you Tony. I was hoping to find some check to save me time from writing a custom one.
Thanks for your reply.
