Web site monitoring - host is critical
jon.bilderback
Post by jon.bilderback »
All of the services return green, but the host itself is listed as critical with "CRITICAL - Socket timeout after 10 seconds"
What service is used to check the host?
mguthrie
Re: Web site monitoring - host is critical
Post by mguthrie »
If you pull up the host configuration, there is probably an entry in the "check_command" field. I'm betting this doc will have what you need.
http://assets.nagios.com/downloads/nagi ... _In_XI.pdf
jon.bilderback
That worked. Thank you very much
