Hello Nagios team, is there any option to not show the header in alert histogram report? like noheader in the legacy histogram
I want to put the alert history of the last 24 hours in a dashboard and I dont want to see the header
regards!
P.D.: im using latest nagiosxi 5.3.2 version
No header option for Alert Histogram report
Re: No header option for Alert Histogram report
Could you show us a screenshot of exactly what part you're referring to?
If it's not possible to remove it currently, we can file a feature request, however one way around it may be placing the tables on it's own dashboard.
we need to remove header form options in Alert Histogram like legacy alert histogram, for exmaple, see the next screenshot for legacy alert histogram with "&noheader" parameters in URL
we need the same for the new alert histogram from nagiosxi
regards!
regards!
avandemore
I have created FR 10115 for this. Please note this doesn't imply if or when this request will be completed, it's simply a request to the developers.
Previous Nagios employee
avandemore
No problem. Is it okay to lock this thread? It will not impact the FR and you are free to inquire about it's status here or via tickets.
