SNMP Trap Sender modification to send Service Groups...
JakeHatMacys
Post by JakeHatMacys »
As titled, I'd like to know if there's a general modification we can make to our Service MIB (without breaking anything) to send Service groups in the SNMP traps for services. Right now we're not seeing them.
The purpose of this is key off of it to identify cleanly what que to send our tickets to.
Has this been done or looked at prior and can anyone aid us in doing this?
Thanks.
ssax
Dreams In Code
Re: SNMP Trap Sender modification to send Service Groups...
Post by ssax »
*** Note: This will get reverted if you upgrade and will need to be reimplemented.
*** Make sure that you have known-good backups/vm snapshots before making any modifications.
You can edit this file:
/usr/local/nagiosxi/html/includes/components/snmptrapsender/snmptrapsender.inc.php
Around line 434 change this line from:
$trap_command = "/usr/bin/snmptrap -v 2c -c $community $tcp$address$port '' NAGIOS-NOTIFY-MIB::nSvcEvent nSvcHostname s \"%host%\" nSvcDesc s \"%service%\" nSvcStateID i %servicestateid% nSvcOutput s \"%serviceoutput%\"";
To:
$trap_command = "/usr/bin/snmptrap -v 2c -c $community $tcp$address$port '' NAGIOS-NOTIFY-MIB::nSvcEvent nSvcHostname s \"%host%\" nSvcDesc s \"%service%\" nSvcStateID i %servicestateid% nSvcOutput s \"%serviceoutput%\" nSvcGroupName s \"%servicegroupname%\"";
Then go to Configure > Core Config Manager > Commands
- Edit the xi_service_event_handler command
- Add this to the end of it:
--servicegroupname='$SERVICEGROUPNAME$'
So it looks something like this:
/usr/bin/php /usr/local/nagiosxi/scripts/handle_nagioscore_event.php --handler-type=service --host="$HOSTNAME$" --service="$SERVICEDESC$" --hostaddress="$HOSTADDRESS$" --hoststate=$HOSTSTATE$ --hoststateid=$HOSTSTATEID$ --hosteventid=$HOSTEVENTID$ --hostproblemid=$HOSTPROBLEMID$ --servicestate=$SERVICESTATE$ --servicestateid=$SERVICESTATEID$ --lastservicestate=$LASTSERVICESTATE$ --lastservicestateid=$LASTSERVICESTATEID$ --servicestatetype=$SERVICESTATETYPE$ --currentattempt=$SERVICEATTEMPT$ --maxattempts=$MAXSERVICEATTEMPTS$ --serviceeventid=$SERVICEEVENTID$ --serviceproblemid=$SERVICEPROBLEMID$ --serviceoutput="$SERVICEOUTPUT$" --longserviceoutput="$LONGSERVICEOUTPUT$" --servicedowntime=$SERVICEDOWNTIME$ --servicegroupname='$SERVICEGROUPNAME$'
That should do it, worked for me, let us know the results.
Thank you
JakeHatMacys
Worked like a charm at first glance.
I'll let you know if our server configuration explodes. But until then thanks a ton!!!
ssax
Dreams In Code
Post by ssax »
No problem, glad we could help.
